Coil spring number
Revelstoke, BC CA
So a customer came in to pick up a rockshox spring today and asked what the first number was before the spring weight. It was 88 and just before the 450lb spring weight. I had never really given it much though. What does the 88 mean?
5/19/2021 5:48pm
Are you seeing a misprinted "# "sign? 'Cause that means pounds. Just in case that's helpful.
Revelstoke, BC CA
5/20/2021 12:38am
Nope, another one had a 73 on it. Got more info after, apparently it's NM per MM
5/20/2021 12:47am
450 lbs/in = 79 N/mm
The mystery thickens.
5/20/2021 1:09am
Just checked a spring on a web shop, it's written "61(350) x 57.5-65MM", and this works since 61 N/mm equals 350 lbs/in.
Post a reply to: Coil spring number
