Tips for Minimzing the Rat's Nest?
Edited Date/Time 8/18/2014 11:24am
do you all have any tips for organizing cables on modern trail and enduro bikes that have remotes all over the place? don't say ride a rigid singlespeed coaster brake bike either haha.
learmiller
N/A, AZ, USA
5/13/2013 11:01am
I zip tie my rear brake and shifter cable together and run them both at even lengths across the head tube. run 1x10 and get a super clean setup.
5/13/2013 11:03am
I run 1x9 and no droper. Simple and clean
PaucH
PH
5/13/2013 11:14am
1. make sure all hoses and cables are cut to almost average length of each other. for most single crown forks try steering your bike 1.5 turns to see if cables/hoses wont get pulled out from fittings.
2. look for cable wrap from electrical/electronics store can also provide extra protection or just zip ties.
3. color code or color match with frame/handle bar color so cables/hose will blend with frame color. & Bike Bling +1
4. sorry but get 1x10 setup with 34 crank, 11-36 casette & forks/shock without remote lock, learn to tune it properly and compromise with fitness, less things to worry about in the long run. if your in the heat of racing you will forget about it anyway. always safer to climb squishy bike than to descend with stiff bike.
from what i understand about enduro is to make your bike mechanically reliable after you get fit.
Goodluck...
Tyrannotaur
Hurricane, UT, USA
5/13/2013 12:08pm
Like PaucH said, if you cut your cables and hoses so that they are all around the same length it helps a lot in keeping your bars looking clean. I try to keep cables so that they run parallel from the shifter/brake lever/remote into their guides in the frame.
I also run a 1x10 setup with a dropper. No lockouts or CTD remotes, so it stays pretty clean.
Mr. P
Rocklin, CA, USA
5/13/2013 1:04pm
Adding to the cables that are similar length, you can tape the cables together for a span to give more of a "one cable" look.
Black tape for black cables, etc.
Black cables for black frames help camouflage the cables a bit.
P
5/13/2013 2:12pm
Not super picky about how it is looking as long as it's riding well. I go ghetto and put electrical tape around shift to brake cables + the dropper.
5/13/2013 4:15pm
1X10 has changed my life. I don't know how I will go back to a 2x.
Also, the underside remote mount for the reverb is pretty slick.
I don't quite understand the need for remote changing of CTD settings. I haven't ever really found the need for high speed changes on the fly.
Any other cables needing love get cut to size, and I will even throw in a zip to get them cleaner.
cuban B
Malibu, CA, USA
5/13/2013 4:22pm Edited Date/Time 5/13/2013 4:27pm
amen to that. i do the same. no CTD or lock out remotes either - three cables total. super clean. keeps the complete bike weight down too. like PaucH said above, if you're racing you wont realize anyway.
5/14/2013 1:37am
Jagwire S hooks on my SB
best advice........ shorten your cables first.
5/14/2013 6:11am
That is pretty sweet, how did he wrap/what did he use to wrap his shifter and rear brake into one?
5/14/2013 9:50am
it looks like heat shrink tubing to me.
5/14/2013 10:06am
Thanks pal, ordered some that looks genius to me!
kyle10bike
Poncha Springs, CO, USA
5/14/2013 8:16pm Edited Date/Time 5/14/2013 8:18pm
I used a heat shink tube just like Moga. Works great and looks clean.
5/14/2013 8:35pm
kyle10bike wrote:
[img]https://p.vitalmtb.com/photos/forums/2013/05/14/585/s1200_P4120085.jpg[/img] I used a heat shink tube just like Moga. Works great and looks clean.
dialed
AMride04
Torrance, CA, USA
5/20/2013 3:10pm
here's mine with a 2x9 set-up and a dropper post
Before
After
I really want to use the heat shrink tube but it's gonna be a lot of work that's why I ended up using an electrical tape.
Not as clean as the heat shrink tube but does the job ok.
I'm running 2x9 set-up. I combined the front derailleur and dropper post cables then the rear derailleur and the rear brake hose.
Tips
Just be creative in using your cable mounts and arrangement of your cables.
No need to use all cable mounts.
You can bundle your cables with ziptie. Just don't lock it too tight.
Post a reply to: Tips for Minimzing the Rat's Nest?
