NikiNu Posts 1 Joined 1/2/2024 Location Beaumaris, VIC, AU NikiNu 1/2/2024 - 1:13am 1/2/2024 - 1:13am Currently I've got a canyon spectral with 150mm rear travel and a super deluxe which is 230x60 would it work to put a coil that is 225 eye to eye and separately would a 70mm stroke be too much for my 160mm fork Thank You Save | Quote Log in or register to post comments Dave_Camp Posts 479 Joined 8/25/2009 Location USA Dave_Camp 1/2/2024 10:10am 1/2/2024 10:10am No 225x70 is a Trunnion mount size and will not fit your bike. 230x60 is standard eyelet size. You could maybe go 230x65- but need to check clearance carefully and will likely void the warranty. You must have JavaScript enabled to use this form. 4 Save Quote Log in or register to post comments tomášpostránecký Posts 9 Joined 1/2/2024 Location CANMORE, AB, CA Fantasy 1004th tomášpostránecký 1/2/2024 5:29pm 1/2/2024 5:29pm I run 230x62.5 on exact same bike without any problems. 230x65 would slightly rub according to Jessy that ran Spectral as 160 rear travel. You must have JavaScript enabled to use this form. 1 Save Quote Log in or register to post comments Start New Topic Share to Facebook Facebook Facebook Share to Twitter Twitter Twitter Post a reply to: Rear shock size help To post, please join, log in or connect to Vital using your Facebook profile Login with Facebook. Breadcrumb Forum Main The Hub
No
