Hurricane, UT, USA
Hey all, long time lurker first post here. Wondering if anyone has attempted using a 210x55 shock on the 5010 v5? Curious if there are any contact issues or unexpected downsides. Would also love to hear if anyone has input on long shocking bikes in general, even if they haven’t done the 5010. For reference, the 5010 is normally 210x50 with 130mm travel. Thanks!
I did it on my 5010 v3 (I know, completely different layout) and it worked great. Current bike (`23 Transition Smuggler) is also long-shocked (55mm stroke instead of stock 50mm) but it's also designed for that.
IME long-shocking is fine as long as you're OK voiding your warranty and it doesn't cause frame interference or make the bike unbalanced.
Depending on how you set your sag the geo could change slightly too (25% at 50mm vs. 55mm) but you can adjust for that too (set sag at 12.5mm)
Hey I’m wondering about long shocking the V5 5010 too. I know it worked on the V4 @ 210x52.5
I emailed Santa Cruz about this a while back as I was curious, here was their response. I never got around to trying it.
cannot help you with that frame, but I have longshocked many bikes before, including, actual "longer" shock, not only stroke.. the good thing with metric is the range of stroke for every E2E.. if it does not contact anything (properly checked) just do it, knowing geom implications, leverage curves are not going to suffer too much IMO.
I have put 230/65 shocks in 222/70 frames, 216x63 shocks on 205/60 bikes (yes, with trunnion adapter, currently on a scout frame my son riders), and so on. dont overlook tire/seat contact, sometimes the offender for a particular setup, having all links working ok. cheers.
Post a reply to: Long shocking 5010 v5
