Silverton, CO, USA
Putting a post out for a buddy. Has GX AXS and mid ride it stopped working properly.
Battery is charged. Light shows green. Light flashes when using shifter. Prongs look good. He can manually move it and hear the motor work and correct things back to gear it was in.. but it will not actually shift out of 2nd highest. Clicking Der button won't shift it and shifter paddle won't either.
So, it's green, communicating, charged, and has motor function.... but not moving. Any thoughts?
I had this happen to my wife’s gx axs system. I really struggled to get the full reset procedure to take… but after many tries over a few days, seemingly doing the same process over and over, it finally took and reset to factory un-paired/grouped components. I repeated the setup process and it’s been fine ever since. Never figured out what did it tbh.
Some things I’d try:
If none of the above work, warranty it. SRAM only has a 2 year warranty but if your LBS has a warranty guy who’s willing to push a bit they usually cave on stuff like this.
Edit: before filing a warranty claim I’d do some isolating of variables; does the shifter work with another derailleur? the derailleur with another shifter?
Post a reply to: Frozen AXS- Help
