Johnstown, OH
I have a 2018 Santa Cruz Chameleon R+ and want to get a new wheel set for her. Currently it has a Race Face AR 40, 32 hole Rim connected to SRAM MTH 746/715 hubs with WTB 3.0 tires (stock). I like the wide tire set up of the + bike.
Im looking at building the new ones with a budget of around $850 in mind.
How does an Industry-9 1/1 XD hubs or DT Swiss 350 36T hubs laced to a DT Swiss XM551 rim sound?
Is the drag really noticeable of a hub with more engagement than what is currently on my bike or are there better bearings in the better hubs to compensate this?
I MTB in central Ohio mostly, hoping for some feed back.
Poll
If you ride a lot of technical trails where precise pedaling is important, high engagement hubs are great. If you aren't doing lots of technical climbing or trying to fit in a pedal stroke in between tight corners, the difference between 10 and 4 degrees of engagement probably won't be as important. Never been to Ohio, so I'm not sure what your trails are like.
The DT 350 was my most-recommended hub when I was working at a shop & doing wheel builds. It's relatively affordable, the durability is basically unmatched, and basic service is easy. I like my Industry 9 hubs too. They're both good options.
Post a reply to: Custom Wheel Help
