EXT Superlight V2 Springs & Rockshox Super Deluxe Coil
ggccvv
quebec, QC CA
I was wondering if you could fit a Superlight V2 straight onto a Super Deluxe Coil without an adapter. The Rockshox ID is 38mm and EXT ID is 38.5mm. I'm guessing the internal diameter expands a little on compression so there must be at least a 0.5mm of wiggle room.
Has anyone tried it?
11/15/2023 1:58pm
ggccvv wrote:
I was wondering if you could fit a Superlight V2 straight onto a Super Deluxe Coil without an adapter. The Rockshox ID is 38mm and EXT...
I've used EXT on the Super D but I used the adapter because EXT spring was too short for a 250x75mm stroke shock.
ggccvv
quebec, QC CA
11/15/2023 2:34pm
Thanks! I'm wondering if the C75 or even a C90 would fit without an adapter on a 65mm stroke SD
ggccvv
quebec, QC CA
11/15/2023 2:37pm Edited Date/Time 11/15/2023 2:37pm
RS springs for 57.5-65mm are 151mm. I'm trying to find the length of a EXT V2 C75 but can't find it.
Post a reply to: EXT Superlight V2 Springs & Rockshox Super Deluxe Coil
