Did I set this up correctly?
MoldyMTB
Calgary, AB, CA
First time changing rotor size, just want to confirm I installed the adapter correctly and everything is aligned properly. cd724b5f-3348-4b1a-9278-ce9b099ea5f1 0237651d3-7b30-41a5-903d-e98c4e5e02ac 05552475f-8bc8-44d3-8cbd-d96e7c98640b 0
8/2/2026 8:06pm
Looks good to me. Youll know if the rotor is too big for the adapter as you wouldnt be able to bolt the caliper down and still be able to spin the wheel. Also if too large of an adapter for your rotor, your caliper will sit sky high it and will be pretty obvious. Sometimes gets confusing if you have a 220 rotor but a 223 adapter cus it still kinda fits. But yours looks right to me. Youll know if u try peek inside at whatever angle to see how the pad and brake track on the rotor line up. They should line up nicely. A couple test stops and you will see the pad leaving some behind on the brake track and itll be obvious if its not in the right spot.
Post a reply to: Did I set this up correctly?
