Elkhorn, WI
9/23/2015 10:38am
Hey guys and girlies, first post to a forum so be easy on me. Bought a new 2015 SantaCruz Chameleon R Build that has a Sram MTH-746 rear thru axle 142x12 hub. It is supposed to be an affordable hub modeled the same as an X9, though the end cap set up seems completely different on my 746 with a jam nut behind the end cap. The bike has only been ridden about 15 road miles with some lift access park riding on it and noticed the rear wheel seems like there is play in it and feeling slight vibe through the pedals while pedaling. I pulled the rear wheel and made sure end caps and jam nut were all nice and tight, but does not seem to make a difference. Does anyone have any thoughts on this besides swapping it out to a King or Hope hub, which i will do if I have to, although seeing it is new figured i should get some use out of it. I read some where else, but only about the X9...couldnt find anything on this 746, of others having a problem, although it was not elaborated on a remedy or what the problem is, they were just quick comments that after resolve happened again and came to there own conclusions that the X9's are just junk hubs with problems and replaced them with Kings and Hopes. Is this 746 being modeled after the X9 indeed just an poorly designed real cheap x9 copy junk hub???? Any advice or suggestions would be greatly appreciated. Bring it back to the dealer on friday to have them look at it/warranty do whatever, problem only santa cruz dealer is 2 hours away, so I will let them take care of it this one time...but thats why im looking for insight because sounds like it is going to just happen very soon again.
Post a reply to: Sram 746 Hub Problems? SantaCruz
