Garrettsville, OH, USA
8/16/2014 10:47pm
Hello, I am looking at getting the Rock Shox XC 28 forks and I was wondering what spring rate to get with it. I weight roughly 120. I was also wondering what other things I need to consider for a novice replacing forks on their own.
If this is your first time replacing your fork, know that you'll need to get a fork that fits in your frame. It should also probably match the travel of the fork you're replacing.
I see that the fork you're interested in comes in several steerer tube options:
1-1/8" STKM steel, 1-1/8" aluminum (-163g), XL 1-1/8" steel, XL 1-1/8" aluminum, 1.5" to 1-1/8" tapered aluminum (-123g), 1.5" aluminum (-146g)
You need to determine if your bike has a 1-1/8" straight headtube or a 1.5 to 1-1/8" tapered headtube. If you can afford the aluminum upgrade it will save you a good chunk of weight.
The XC 28 is offered in 80/100/120mm travel options. Measure the travel on your current fork using a tape measure.
https://www.sram.com/rockshox/products/xc-28-tk-0
When you get the new fork, you'll have to cut the steerer tube and install a new star nut inside the steerer. This can be a little tricky, so consider having a shop show you how the first time.
Post a reply to: Rock Shox Spring Weight?
