Hi, I wanted to convert to tubeless but ran into problems with installing the valves. Rims are the Roval Traverse and valves are the Roval Control. The lower part of the valve (smooth, without thread) does not fit through the rim hole. The rim hole cannot be sealed by the valve's O-ring, as the valve cannot be completely inserted through the hole. Here is a picture of the valve: https://cdn.shopify.com/s/files/1/1342/0697/products/30015-1053_WHL_MY1…
According to Google research and the Roval website, the valves should be the right ones. Anybody have any idea what might be the problem here? Is there a trick or what am I missing? Any ideas?
I thought installing the valves would be the easiest part of going tubeless
Hope some of this is helpful. But, again, you're probably going to get better answers from somebody who can assess the situation in person.
Thanks for your help!
Post a reply to: Problems installing Tubeless Valves. What am I doing wrong?
