3/20/2015 4:48pm
These are the photos from a DirtMag site article that I can't seem to find anymore...
IMG_1245.jpgIMG_1246.jpgIMG_1247.jpgIMG_1248.jpgIMG_1249.jpgIMG_1250.jpgIMG_1251.jpgIMG_1252.jpgIMG_1253.jpgIMG_1254.jpgIMG_1255.jpgIMG_1256.jpgIMG_1257.jpgIMG_1258.jpgIMG_1259.jpgIMG_1260.jpgIMG_1261.jpgIMG_1262.jpg
The DH bike geometry is... wb 1190mm, bb 345mm, down tube 700mm, ha 62.5 deg, cs 412.5mm
How does a 412 CS feel like?
First Google hit for big bird dirt mag :D
How does the long front centre deal with putting your weight over the front axle, is it a problem? Can you use flats or do you have to hang over the front so much that you need to be clipped in to prevent from blowing off the pedals?
I'm thinking about a 420 mm chainstay, 650ish mm top tube, 75° seat-tube angle and a 65° head angle for an enduro class bike (it would give about a 1230 mm wheelbase), which would be a large L compared to other brands and in most cases about 30 mm longer on the wheelbase (i'm 190 cm, so in most cases right between the L and XL frame).
I'm affraid how a bike like that would handle and go uphill, with such a long front end and a short rear end. Granted, it would have a really upright seat tube, which moves the centre of gravity (of the rider) quite a lot further forward, which would help a lot.
And i feel the pain of tall frames, i currently still have a Commencal Meta 5.5 of a 2008 vintage, that has a 68.5° seat angle, where the seatpost is fully extended. My ass is right about at the halfway point on the chainstay since the seat gets so far back. I don't like that much and i even more strongly dislike the fact that when lowered, the seat is so weirdly forward (the seat tube is offset to the front about 5 cm compared to the BB, the angle is actual, not virtual as far as i know).
Down tube 30.5", seat tube 21" at 76 deg, actual top tube 25.5", head tube 5" at 66 deg, BB 13", wheelbase 48" plus fork offset, chain stays 16 5/8, and the main pivot at 5" from the BB.
I hate the feeling of pushing forward to go forward that the tall are generally subjected to. I want to push more down like everyone else. The steeper seat angle also makes room for the shorter rear end to keep the longer front end feeling lively and puts weight forward to weight the front tire. Win win win, I think, but I haven't built it yet so who knows. It may be totally whack. I think golden.
A friend of mine who's finishing up his kinesiology PhD actually said that a steeper seat tube angle is more efficient, so there's that.
The chainstay is basically the same as i chose, a smidgen over 420 mm, same goes for the top tube, 650 mm. I've been throwing head angle numbers around, going from 65 to 66,5 in half degree increments, and the wheelbase differs by 6 mm for each half degree, going from 1238 mm at 65° to 1220 at 66,5°. With your one degree steeper seat tube you should gain a few mm on my numbers (66° at 1226 mm), so i suppose 1230+ mm or 48,5 inches should be easily achievable.
Have you thought about going with a virtual pivot point suspension design? Well, horst link is more or less the only way to go with a chainstay that short...
Also, 26" wheels then? I'm basing my numbers on 650B wheels and an appropriate fork.
Post a reply to: Big Bird's Bikes
