1/28/2019 5:59am
I'm in Sydney so there will be postage for most but our dollar is shit so these are likely a steal for anyone in US/UK/Canada etc...
Code R brakeset and rotors 200mm: $450
Take-offs from new bike, have ridden around the parking lot and that's it.
Code R, front and rear levers and calipers and two 200mm rotors. Front won't need bleeding, rear needs a line.
Rear rotor has a small tap hole from where the magnet was fitted – came off an ebike, hence saints fitted. $450
Rearwheel: DT350, 32H, 148Boost, Centrelock, XD driver.
DT XM551 275 32H 40mm rim. $200
Had to switch to a 6 bolt hub for the aforementioned magnet. Took the chance to update the rim. Rear wheel has done 2544klm.
$200 for the wheel.
$200 for the wheel.
Post a reply to: Code R brakeset & rotors 200mm. DT 350/XM551 Wheel
