Luke Afb, AZ
I have the mechanical X01 eagle on my SB130 LR and one of my cranks had some slight damage recently. Found some T-type XX cranks nearby and was wondering if there’s any compatibility issues, whether the spindle would make a difference between DUB and DUB wide, or anything else to know. I ride, I lurk, but admit I’m not the most savvy on some mechanical things - so thanks in advance 🙂
Shouldn't be an issue; DUB gives you a 52mm chainline. DUB Wide is 55mm so your Q-factor increases by 5mm and your neutral chainline (where the chain runs straight off the chainring to the cassette) will be 2.5mm further outboard on the cassette.
It might make a little more noise on the biggest cog until it beds in.
Thanks! I was thinking if using a DUB spindle, it shouldn’t affect the chainline so much
Post a reply to: T-Type cranks with eagle groupset?
