29×2.5 Minion dhf on Flow ex width?
nuke
Edited Date/Time 1/27/2016 11:12am
If anyone is running this setup could provide an overall width in millimeters I would appreciate it. Trying to determine if the tire will clear my brake arch. Currently running Ardent 2.4 but it is severely lacking grip in the wet. At 20psi the Ardent measures 61.5mm with 6mm clearance on the sides and about 8mm above the tire.
SHO
San Jose, CA, USA
1/27/2016 11:12am Edited Date/Time 1/27/2016 11:13am
Hi Nuke,
the folks from bitingtires.com measured 64mm on a 30mm rim (internal width). If your rim is 25mm, you should end up with about 62-63mm.
Sorry, I don't have the exact numbers, but I hope it helps,
Sho
Post a reply to: 29×2.5 Minion dhf on Flow ex width?
