Scott Gambler 20
Edited Date/Time 8/18/2014 2:09am
For sale is a Scott Gambler 20. Below is the part list that came on the bike. Everything is in very good condition, I have installed some BRAND NEW parts and all of them have been ridden on 2 or 3 times. This bike is a beast and has adjustable Geometry. The HA can be adjust +/- 1.5deg, and the Rear Travel can be adjusted from 6.5-9.2 inches.
NEW PARTS: Cassette - SRAM PG-970DH, Chain - PC-991 w/ Power Link, Pedals - Blackspire Sub4 Red, Brakes - Shimano ZEE w/ ICEtech pads, Grips - RaceFace Red Grips.
Like I said the bike is in excellent condition, the front wheel may need a truing, but it rides fine. I dont have time to ride anymore, I am working full-time and working on a Masters in Finance.
I am looking for $1500, I will consider other REASONABLE offers so just shoot me a msg with your offer, no low balls please.
(Note: The current photo is without the new parts installed)
Below is what came stock on the bike, it is still on the bike unless it has been replaced by the new parts:
Frame & Fork
Frame Construction TIG-welded
Frame Tubing Material 7005 aluminum
Fork Brand & Model Marzocchi 66 RCV, 180mm travel
Fork Material Single
Rear Shock Fox Vanilla R Coil, 190-230mm
Components
Component Group Downhill Mix
Brakeset Avid Juicy 3.5 hydraulic w/203mm rotor brakes, Avid Juicy 3.5 hydraulic levers
Shift Levers SRAM X.5 Trigger
Front Derailleur Not applicable
Rear Derailleur SRAM X.7
Crankset Truvative Ruktion BG 1.0, 34 teeth
Pedals Wellgo LU-A8D SCT
Bottom Bracket Truvativ Howitzer Team
BB Shell Width 83mm English
Rear Cogs 9-speed, 11 - 34 teeth
Chain SRAM PC-951, 1/2 x 3/32"
Seatpost Scott Pilot FR (telescope)
Saddle Scott Gambler
Handlebar Scott Pilot FR 1.5 Pro
Handlebar Extensions Unspecified
Handlebar Stem TruVativ Holzfeller OS
Headset 1 1/8" threadless VP Cr-Mo Cups
Wheels
Hubs Front: Scott Pro, 20mm, Rear: Sun Ringle Lawwill, 12mm thru axle, 150mm wide
Rims SUN Single Track, 32-hole
Tires Front: 26 x 2.50" Maxxis Minion DHF supertacky, Rear: 26 x 2.50" Maxxis High Roller 60a
Spoke Brand DT Swiss stainless steel, 14ga. (2.0mm)
Post a reply to: Scott Gambler 20
