2011 Specialized Camber Pro
babineau
Concord, NH US
Edited Date/Time 8/16/2014 7:56pm
I am looking to sell my Camber Pro. This bike is a large and has been very well maintained. I am a professional bicycle mechanic, and like my stuff to run flawlessly! There are the normal scratches and cable run spots, but nothing beyond cosmetics. I have upgrades much of the drive train. Full spec list below. I am open to offers so let me know what your thinking! I will also include an extra hanger or two! - Thanks
FRAME M4 hydroformed tubing, sealed cartridge bearing pivots, disc only, Command Post routing, replaceable deraileur hanger, bolt on cable guides, 120mm travel
REAR SHOCK Custom Fox Triad II for Specialized, custom on-the-fly 3-position switch 1) lock out 2) Open 3) ProPedal, rebound adj., 7.875x2.0"
FORK Fox F120 RL, air spring, reb adj., LO, standard drop-outs, disk, 120mm travel
HEADSET 1 1/8" upper and lower campy style cartridge bearings for integrated alloy HT
STEM Specialized XC, 3D forged alloy, 4-bolt, 31.8mm clamp, adjustable rise
HANDLEBARS Specialized XC low-rise bar, 7050 butted alloy, 680mm wide, 8 degree back sweep, 6 degree up, 31.8mm
GRIPS Specialized lock-on, Rocca
FRONT BRAKE Custom Avid Elixir R SL, hydraulic disc, reach adjust, alloy backed semi-metallic pads, stainless hardware, G3 Clean Sweep rotor, S/M: 185mm, L/XL: 203mm
REAR BRAKE Custom Avid Elixir R SL, hydraulic disc, reach adjust, alloy backed semi-metallic pads, stainless hardware, G3 Clean Sweep rotor, S/M: 160mm, L/XL: 185mm
BRAKE LEVERS Custom Avid Elixir R SL hydraulic, tool-less reach adj.
FRONT DERAILLEUR SRAM X.7 10-speed, S3 direct mount for DMD, bottom pull
REAR DERAILLEUR SRAM X.9 Type 2 (Roller Bearing Clutch) mid cage, 10-speed
FRONT SHIFTER Shimano SL-M660-10R SLX, 10-speed, trigger
REAR SHIFTER SRAM XO 10-speed, trigger
CASSETTE Shimano HG81, 10-speed, 11-36t
CRANKSET Custom SRAM Carbon S-2200, 10-speed XC Trail double, GXP spindle, removeable spider, 175mm
CHAINRINGS 38A x 24A, 4-bolt, 104/64mm
BOTTOM BRACKET SRAM GXP, outboard bearing
PEDALS Not included
RIMS Custom DT Swiss X420SL, 24mm w/ eyelets, 28/32h
FRONT HUB Specialized Hi Lo disc, laser-etched logo, OS 24 end caps, sealed cartridge bearing, RWS, 28h
REAR HUB Specialized Hi Lo disc, lasere-etched logo, double sealed cartridge bearing, QR, 32h
SPOKES 1.8mm (15g) stainless
FRONT TIRE Continental Mountain King 2.2
REAR TIRE Continental Mountain King 2.2
INNER TUBES Ultralight presta valve
SADDLE Specialized OEM Body Geometry, 143mm width
SEATPOST 2014 butted alloy, single bolt setback, 30.9mm, S/M: 350mm, others: 400mm
SEAT BINDER 34.9mm clamp ID, alloy collar w/ QR, black
Post a reply to: 2011 Specialized Camber Pro
