I have a Range, and also used to have Canfield Jedi back in 2015-ish. My take on the most common HP concerns:
-The idler drag is noticeable, but it isn't extreme. I've heard people say the idler reduces the efficiency of the drivetrain by around 2%, and I'd believe that. Years ago, I had some Hammerschmidt cranks (with the internal planetary gear), and supposedly those things added about 9% inefficiency. I couldn't deal with the Hammerschmidts - they were too draggy, but the idler doesn't bother me that much. I still wouldn't want an idler on a lighter weight bike that was more oriented towards climbing, but it's fine on an enduro sled.
-The high pivots jump just fine off of actual jumps. What they don't do as well is pop off of little roots or rocks. Jumping off of something that's at least as long as the bike's wheelbase feels essentially the same as jumping on a non-HP bike. But tagging a little bump with the rear wheel to get some pop doesn't work quite as well - the wheel moves backwards and out of the way (which is the whole point of the high pivot), and that robs you of some of your pop. It's not impossible or anything, but it's a little more work than on a non-HP bike.
-Manualing a high pivot bike is harder.
-My old Jedi cornered weird. As you pressed into a corner and the suspension compressed, the wheelbase stayed roughly the same (whereas on a non-HP bike, the wheelbase gets shorter; the front wheel moves backwards at the angle of the headtube, and the rear wheel moves forward-ish around the main pivot). If you were used to a "normal" bike, this made the Jedi feel long and cumbersome in corners, and it took some getting used to. I haven't had that same need for adjustment with the Norco - from my first ride on it, I actually felt like it cornered really nicely and very intuitively. I mostly chalk that up to the Norco having less rearward travel than the Jedi, and the Norco's geometry suiting my personal front / rear weight preferences.
-I haven't had any noteworthy maintenance issues with my idlers, but I know others that have. This probably depends on the specific bike, the specific bearings, and the weather you're riding in.
