9/5/2019 1:23pm
Hello,
I have a Trek Powerfly full-suspension E-Bike 2019.
I am a beginner to mountain bikes, and so unfortunately I don't know what I'm doing.
My Trek comes with a Rockshox Deluxe RL shock, which has a 2 position blue compression knob; please see photo below:
I was experimenting with my shock before understanding that my compression knob had only 2 settings (locked, and open - see blue graphic on the shock in the photo above).
But in experimenting with compression, I saw only at the red graphic on the shock - thinking it was for the compression dial (when in fact the graphic is for the rebound adjustment).
Looking at the red graphic, I turned the knob (too forcefully) counterclockwise (when looking at the knob from the front) - beyond it's intended range.
The knob now clicks at three positions, instead of the intended two (lockout and open):
The third photo in the series above shows the artificial 3rd position/click (at 4 o'clock) that I caused after forcing the knob too much counterclockwise.
The closed/lockout (8 o'clock) position still appears to work, as does the open (6 o'clock) position.
Nothing seems to change when I move the knob from the open (6 o'clock) position to my artificially created 3rd position/click at 4 o'clock.
I took the bike to the bike shop; the mechanic said the shock still works, so don't worry about it, just keep an eye on it.
I'm very OCD - I was thinking I should have the shock replaced.
I'm embarrassed to go back to the shop and ask for an unnecessary replacement (I would pay the cost of-course).
But is my mechanic correct in saying a replacement is not necessary?
By forcing the knob to a 3rd position or stop - is the shock indeed still good, is it safe???
(I read somewhere in another forum in which the poster said his knob was broken, and as a result, he saw oil leaking out the knob.
And a YouTuber said in a video a broken shock under pressure could blow up).
So my question is: - should I just "keep an eye on things" as suggested by bike shop, or should I just purchase a new one?
Thanks in advance!!
Thanks in advance!!
Thanks so much for your input!!
That helps a lot!!
This was a common issue- the newer RL models have a lever that spins a full 360 (with lockout being lever pointed up and open being down)
Post a reply to: Did I bust my Rockshox Deluxe rear shock?
