Quick scroll though and I didn’t see this yet. Bottom of semis right now and noticed yet another new addition to Myriam’s commencal.Edit: Amaury on it...
Edit: Amaury on it too.
Did I miss a discussion about the NDS steel chainstay? Only seen it on the drive side up until now...
Floating brakes making a comeback? The Foes 2 pages back has one too...
I'd say they are testing some things. After all, they moved the pivot from seatstay to the chainstay and back. On a 6bar bike this will give a different result just like moving it on a 4 bar (single pivot vs. Horst link).
Amaury's too, and they found some paint for his stays. 😅
Same experience with the DH casing ones, but the trail casing one I had on the short travel bike got unusable after two bike park runs...
Same experience with the DH casing ones, but the trail casing one I had on the short travel bike got unusable after two bike park runs, it warped so badly it was almost touching the frame.
Isn't this now two semi-independent six bar linkages?
Kind of, a floating brake arm effectively makes a separate linkage arrangement for the brake which is why it can have completely different anti rise ccharacteristics
Yeah, no effect on axle path and chain tension. I understand the application but what I haven't seen before (in my very limited experience) is its use on a true six-bar?
Anyway I can't decide whether that "eight bar" comment on Pinkbike was even intended to be serious.
Pedalling wise it's a 6 bar. Braking wise it's an 8 bar.
There are 2 bars connecting the main triangle and the rear axle. Rear axle path is defined by a 6bar linkage. 6+2 defines the movement/rotation of the brake link.
This is the exact reason why split pivots are single pivot pedalling wise but 4 bar braking wise.
So as was sort of pointed out a bit earlier in this thread... Dak's interview confirms that the High Roller 3 (at least DH version) is...
So as was sort of pointed out a bit earlier in this thread... Dak's interview confirms that the High Roller 3 (at least DH version) is on the new un-announced Maxxis casing that they've been developing for a while. I'm sure partially or wholly in response to Continental. Neko mentioned that Maxxis was working on casings for a while but they weren't going to be ready for the 2024 season so they went to Continental for the higher performance envelope of their tires. I'm assuming Maxxis is tooling up to get the DHR2 and Assegai ready to ship with this new casing before coming out with the news. Sounds official launch is still ~2 months away though. The tire casing wars heating up lately!
After my friend @jeff231 made a comment about the Highroller 3 being sturdier than his DHR2 at the Snow Summit Monster Energy Pro Downhill Series and Jason making a similar comment on B Practice I went down to a bike shop yesterday to see if there was a difference in the sidewalls. Sure enough, the Highroller 3 has what feels like one of those anti-thorn strips running from the bead to about 3/5th up the sidewall under the rubber. I'm assuming it's primarily pinch flat protection but Jason and @jeff231 both indicate that it offers more support in the tire as well. This is probably that "breaker" casing which we've seen at the world cup for a couple years now.
Shop staff Said the Hightower is coming in about 2 weeks.
Same thing goes for the new Troy from devinci.
Both bikes will only come in AXS for now, since the release of GX and NX t-type has been delayed to spring 25. They will have another release then with lower speed models.
Supposedly this is what's is pushing the release of the aluminum Stump jumper as well.
After my friend @jeff231 made a comment about the Highroller 3 being sturdier than his DHR2 at the Snow Summit Monster Energy Pro Downhill Series and...
I got a set in the mail yesterday, the sidewalls definitely seem stiffer than the used Assegais I have sitting in the garage. 2800g+ for an MX set.
Kudos to Maxxis for finally dumping the plastic hang tags for cardboard too.
HAHA! I'm dumb and wrong. @ewebster noticed it was his Giant Reign E+. False alarm. Go watch the video anyway because I want to go to Montana to ride stuff like that and I can't.
From the camera angle that logo looks like it could be a Forbidden logo (nevermind that upside down thing...brains do weird stuff) but I had half a hunch I had seen that top tube display before. Turns out I had!
Well, I'm leaving that post up because I want to go ride those trails in Montana and Brian seems like a good dude and deserves some more views.
The WC exclusive casing was the ZK casing, I'd say kevlar reinforced with tech coming from the road side of things.
The new HR uses a different butyl sidewall insert than the rest of the current DH line with the goal of creating a more stable and damped (dampened) casing.
ZK is a super tough, light, and flexible material originally used on our road tires. For the team spec DH casings it's used as a breaker layer underneath the tread for puncture protection.
Frameworks Enduro rig is officially official and open to the public. Death knell of the X2? They didn't even try to sell it with one and just went straight float x or vivid.
Frameworks Enduro rig is officially official and open to the public. Death knell of the X2? They didn't even try to sell it with one and...
Im not sure if its the death of the x2. They also use the dhx on the downhill bike instead of the dhx2. Seems they like the way they can tune those shocks to the bike better than the x2 and dhx2
I think it was never one sided?
Edit; Killed me with your edit Jesse! 🤣
Horses for courses
Found these pics from Ft. William and they're painted there too: https://www.pinkbike.com/news/even-more-tech-randoms-fort-william-world-cup.html
Guess I haven't been paying close enough attention...
Good spot. 👍
Pinkbike says 8th bar anti-rise mod.
Engineer: "How many points of articulation should the rear suspension have?"
Max Commencal: "Yes."
The true n+1, where n is the number of bars
He must own stocks in a ball bearing company.
Also wouldn’t this just be 7 bar?
I’d call it a 7 bar design.
The 8th bar is the part the brake is bolted to, which rotates independently from the seatstay where it's usually mounted.
I think Brian Cahal on YouTube is riding a Forbidden ebike.
Just after https://youtu.be/i1Qln-KXKOc?si=j1u77CQDJy13Ophs&t=115 you see a display on the top tube and hear him being assisted while pedaling. What a weird way to have to form that sentence.
He's on a Giant Reign E+. https://www.youtube.com/watch?v=EuNLJ3wQ1Rc&ab_channel=BrianCahal
Yep. That's 100% it. Good spot!
Forbidden E-bike is coming end of this year / early 2025. Possibly SRAM motor.
Yeah, I got the impression it was a price point, not a performance thing
