5/9/2022 3:11 PM
No update to enduro confirmed by spesh
5/9/2022 5:48 PM
That’s what they always say months before dropping the new latest and greatest, gotta keep ‘em rolling out the doors
5/9/2022 6:25 PM
Looks like they've taken it down. Anyone hear of a eta?
5/9/2022 9:48 PM
bengt.leon wrote:
If we already have talked about this, then never mind. But look at this öhlins shock on Ben walkers bike. Photo
Javi_NoFer11 wrote:
Isn't that the Scott Ramson specific piggyback?
Lol, found it! It looks like it have been out since 2019?
5/10/2022 10:21 AM
5/10/2022 1:53 PM
Smooth feeling system…..
I love this for you
5/10/2022 3:36 PM
"Man, it's rough out there on the track today. I either need to add some high speed compression, bump up my fork pressure, add some low speed compression, add a token, pump up my tires, add a front tire insert, raise my bars, or increase the psi in my stem suspension. One or the other, I think."
5/10/2022 5:18 PM
Edited Date/Time: 5/10/2022 5:43 PM
Re: Neken stem
Sometimes more is more, sometimes it's not.
We all want a more comfortable and controlled ride. To that end, many riders want to add all the suspension: tires, rims, spokes, chassis, stem, bar, grips, gloves. The problem is that not all of it is effective at the same frequency or amplitude, and those that act on the same frequency and amplitude are not always of the same quality.
For example, imagine if you wanted to create a DH set-up. You could take two XC air springs and dampers and just stack them on top of each other, or you could use a single, long air spring and damper. The latter has the potential to be better because you avoid redundant components, don't have to double the valve float, etc. This is an example of systems that work on the same amplitude and frequency, so we choose a single, superior system and extend the travel as desired.
Now, compare the action of the fork and tires. We currently have about 8" of fork travel and 2.5" of tire travel. Alternatively, we could have 10.5" of fork travel and just coat our rims in some rubber lugs, or we could have a rigid fork with a 10.5" tire casing. The former alternative is obviously poor because the nearly zero unsprung mass of the tire handles impacts of high frequency and low amplitude that the fork doesn't handle efficiently. The latter alternative is obviously poor because 10.5" of travel needs damping over most of the stroke. Maybe 7.75" of fork travel and 2.75" tires could be better, or 8.25" of fork travel with 2.25" tires, but the current system is clearly close to ideal and better than the extreme alternatives.
As a final example, consider rotating grips (ex. Rev Grips, or simply squishy ones, like Oury). These act in a direction that's not covered by the fork, tires, or a Neken stem. Adding a grip that increases movement around the axis of the handlebar does something the other options don't do.
So, to get back to the Neken stem: it acts on the same axis as the fork and, with such short travel, the flex, float, and stiction affect a larger fraction of its travel than the fork's travel. The stem is effectively the same as adding a little fork travel, but of lesser quality, requires redundant components, and there's more unsprung mass below it. If the goal is to add a little "soft" suspension to the existing fork travel, it's probably sought because the fork is sticky; for the expense of this stem, a fork manufacturer could improve tolerances and/or use exotic materials in the fork to address friction. Or maybe it's to create a layer of suspension with less inertia that reacts more quickly, in which case a simpler system would likely be the better solution. It's unlikely that stacking a telescoping suspension stem on a telescoping suspension fork will create a superior result unless that scales of travel or mass are enormously disparate - likely beyond the situation on a motorcycle and almost certainly beyond the situation on a mountain bike.
5/10/2022 5:42 PM
This neken stem should be a dropper stem, for geting as low as possible for climbs and high as possible for descends.
I could not fancy any other utility for this design. Even the turning radius would be so wack, steering lock and all...
5/10/2022 5:44 PM
30 years ago, I had the exact same thing.... was called a girvin flexstem
it worked like a normal stem, but had a little skateboard truck bushing in it to give around 1 inch of bar travel. At the time it was pretty revolutionary and worked pretty good.
I remember going to a skateboard shop in the early 90's, buying out all their bushings to figure out which one worked best. I've been puzzling with suspension ever since smile
5/10/2022 5:54 PM
brash,
It's 1987 all over again:
5/10/2022 9:01 PM
R-M-R wrote:
Re: Neken stem
We all want a more comfortable and controlled ride. To that end, ...more
I think it is reasonable to imagine that this stem, carrying far less weight than the fork, could be tuned such that it could make for a more comfortable ride: reducing peak forces on your hands in a way that a fork can't.
I also think it is clearly a different situation than using two short shocks instead of one long one - In that case both shocks carry identical loads. The stem typically carries far less than half of your body weight, and none of the bike weight.
I'd be very interested to read independent reviews - Seems like it could offer a very different experience over rapid bumps where perhaps a fork might get deeper into its travel - and therefore be stiffer.
I can even imagine improvements in traction, as perhaps this stem could further reduce bucking the rider, smoothing out the loading on the ground/tire.
5/11/2022 12:47 AM
potorider wrote:
I think it is reasonable to imagine that this stem, carrying far less weight than the fork, could be tuned such that it could ...more
I could see beneficial uses for the stem in a gravel bike or touring application and maybe at a stretch even marathon racing on MTB where reducing very high frequency small vibrations might add up.
5/11/2022 12:50 AM
Fun fact, Neken manufactured a batch of MTB handlebars back in 2010 for a local bikeshop, 750mm wide and 22.2mm clamp and something like 20-30mm of rise. Had one back then with spacers to fit on a 31.8 stem.
Contacted the company a few years later, as I wanted one for a project and was hoping they had some, and they did! Also got a tour of a part of the manufacturing floor, awesome guys to talk to. And back then they didn't have plans in the near future to go back to MTB, but I suppose now they do.
5/11/2022 3:14 AM
Pretty sure this was invented entirely for guys who bought a trust fork and want to double down on degrading their riding experience. Luckily for neken those type of guys ride in packs and have money to spend.
5/11/2022 4:38 AM
bulletbass man wrote:
Pretty sure this was invented entirely for guys who bought a trust fork and want to double down on degrading their riding ...more
Imagine this stem coupled with a set of Fasst flexx bars
5/11/2022 7:06 AM
5/11/2022 7:25 AM
I ...more
I also try to get as high as possible for descends.
5/11/2022 7:31 AM
The 'high frequency' loads experienced by our hands, the chatter, is best dealt with something flexible. This stem will have too much stiction to have any effect for these kinds of loads. What you need is rubber inserts (cue buttercups), flexible bars (OneUp carbon bar...), soft grips, etc.
When it comes to vibrational damping with professional equipment, vibroinsulating foams are used, in the gloves, the grips, etc. Springs could be used as well, by the logic of a tuned mass damper, but that needs to be finely tuned to the application - which frequencies you want to filter out, what the masses of the system are, etc. There is too much variation in cycling world for that to function, even dampers and springs in our forks and shocks often have problems in the bell curves of the gaussian distribution.
5/11/2022 7:51 AM
specialized creates "Globe" brand for utility e-bikes
...more
have been told globe used to exist in early 2000s, too. i'm not in touch w/ this side of the cycling marketing, so anyone know if they cut it off and are re-launching?
5/11/2022 8:34 AM
Edited Date/Time: 5/11/2022 10:14 AM
...more
have been told globe used to exist in early 2000s, too. i'm not in touch w/ this side of the cycling marketing, so anyone know ...more
This would be the third go-round for the Globe brand. First launched in the '90s, relaunched in mid '00s.
MRP - VP of Business Dev.
5/11/2022 8:41 AM
...more
i recall seeing it in some of the giant catalogs when i was a shop rat in the mid '00s. at that time it was for their commuting oriented bikes.
5/11/2022 9:03 AM
R-M-R wrote:
Re: Neken stem
You sure talk a lot! laughing tongue
What about these just coming out for road/gravel bikes as their intent?
5/11/2022 9:23 AM
was sent another photo of the neken stem mounted to a bike and am waiting for reply to see if i can post it here. it's on a husq ebike in the shot, so it's not a gravel/short-travel thing.
5/11/2022 10:09 AM
was sent another photo of the neken stem mounted to a bike and am waiting for reply to see if i can post it here. it's on a ...more
Don’t toy with us like that,
You have the goods, just post it anonymously, sit back and watch us lose our minds.
PB commenters will have a field day with it bolted to an ebike….
5/11/2022 10:52 AM
Edited Date/Time: 5/11/2022 10:53 AM
permission pseudo-granted. (and i post stuff here for vital members...don't really care what pb commenters have to say)
5/11/2022 11:00 AM
What kind of bump stops are they going to implement to not smashing the head tube? Limiting turning radius and no X-ups or toboggan for sure. Seems like someone didn't think this thru.
5/11/2022 11:03 AM
At least it looks good... Photo
5/11/2022 11:13 AM
The Vecnum suspension stem is actually really good on a gravel bike on rougher tracks.
5/11/2022 11:17 AM
Oh yeah, looks reeaaall good...
