FOR SALE 2013 Specialized S Works Enduro $6900 OBO
7/8/2013 2:41 PM
Edited Date/Time: 7/8/2013 4:48 PM
2013 Specialized Enduro S Works size Med. $6900 OBO
This bike is basically brand new. I got it about four months ago and it has sat in my garage till now (due to weather) and now unforeseen circumstances came up to were I must sell it (HURT MY SHOULDER). I have NEVER ridden it. It has two sets of new tires with it. One set is Purgatories and the other ground controls. Neither have been ridden on. All parts are what the specialized site says except I put Thompson All Mountain carbon Bars on it. This bike is in NEW condition. I will have a local bike store pack it and ship it to you and you are welcome to call them as well to verify the condition. Buy pays for packing and shipping (insurance) . If some one in Canada buys the bike they pay applicable taxes. I am asking $6900.00 OR BEST OFFER/ OR BEST OFFER? OR BEST OFFER. I will CONSIDER ALL REASONABLE OFFERS. contact me via phone or text at 915-401-9627 or email at jiminthesand@ yahoo.com I can text you more pics to upon request.
FRAMEFACT IS-X 11m carbon front triangle, M5 rear triangle, tapered HT, PF30 BB, ISCG 05 mounts, 142 dropouts, full cartridge bearing pivots, replaceable derailleur hanger, 165mm travel
REAR SHOCKCustom Cane Creek Double Barrel Air, high/low speed, comp and reb adj., 216x64mm
FORK Rock Shox PIKE Dual air (NEW)
HEADSET1-1/8 and 1-1/2" threadless, Campy style upper with 1.5" lower, cartridge bearings
STEMSyntace F109, 6-degree rise, 31.8mm clamp
HANDLEBARS Thompson All-Mountain low-rise bar, uni-directional carbon, 720mm wide, 8-degree backsweep, 6-degree upsweep, 31.8mm
GRIPSSpecialized Sip Grip, half-waffle aramid-infused, S/M: Regular, Others: XL thickness
FRONT BRAKECustom Avid X0 Trail World Cup, alloy backed semi-metal pad, 4-piston caliper, 200mm rotor
REAR BRAKECustom Avid X0 Trail World Cup, alloy backed semi-metal pad, 4-piston caliper, 180mm rotor
BRAKE LEVERSCustom Avid X0, carbon lever, tool-less reach adj.
FRONT DERAILLEURN/A
REAR DERAILLEURSRAM XX One, 11-speed
SHIFT LEVERSSRAM XX One, 11-speed, carbon/aluminum trigger, w/MatchMaker clamp
CASSETTE SRAM XX One, 11-speed, 10-42
CHAINSRAM XX One, 11-speed, hollow plates/pins, nickel finish
CRANKSETSRAM XX-One, carbon arms, single 34T ring, PF30 spindle w/E13 Guide, S: 170mm, Others: 175mm
CHAINRINGS34T, 32T ring included
BOTTOM BRACKET SRAM PF30, OS press-in bearing, sealed cartridge
PEDALSResin Test Ride Pedals with toe clips, CEN std.
RIMSRoval Traverse SL, carbon disc, 29mm, 27/32h
FRONT HUBRoval Traverse SL, 15mm thru-axle end caps, 27h
REAR HUBRoval Traverse SL 142 , DT Swiss Star Ratchet, 12mm thru-axle, 32h
SPOKESDT Swiss Super Comp, 2.0/1.65/1.8 stainless
FRONT TIRESpecialized Butcher Control, 2Bliss Ready, 60 TPI, aramid bead, 26x2.3"
REAR TIRESpecialized Purgatory Control, 2Bliss Ready, 60 TPI, aramid bead, dual-compound, 26x2.3"
INNER TUBESUltralight presta
SADDLEBody Geometry Henge Expert, Ti rails, 143mm
SEATPOSTSpecialized Command Post BlackLite, 3 position, adjustable height w/air spring, remote operated, single bolt head 30.9mm, S:100mm travel, Others: 125mm travel
SEAT BINDERCommand Post 34.9mm clamp, 7050 hard anodized alloy collar, single bolt w/cable guidePhoto
