2012 Specialized Stumpjumper FSR Expert EVO 29 XXL
10/30/2013 11:39 PM
-Well taken care of and heavily upgraded AM 29er for the tall folks
-Fox Float RP23 Adaptive Logic Shock, Fox 34 Float 29 FIT RLC 140mm Fork (Both recently rebuilt by Suspensionwerx)
-NEW Elixir 9 Brakes
-BRAND NEW drivetrain! Full Sram XO, X9, X7, SLX Groupo
-Specialized Command Post Blacklite
-Specialized Butcher and Ground Control 29er tires (Spare Captain tires as well!)
-Raceface bar and stem
-Great do everything bike for anyone over 6 foot 4 inches
-Roval Traverse 29 AM Wheelset with DT Star Ratchet rear hub
-Full spec:
FRAME
M5 hydroformed tubing, 29" EVO geometry, tapered HT, PF30 BB, ISCG ’05, Command Post routing, 142mm dropouts, sealed cartridge bearing pivots, replaceable derailleur hanger, 135mm travel
REAR SHOCK
Fox RP23 Adaptive Logic with AUTOSAG, Kashima coating, rebound adj., separate climbing setting and custom 3-position open comp adj., 197x46mm
FORK
Fox 34 Float 29, FIT RLC, Tapered, 15mm Axle, 140mm Travel, White
HEADSET
1-1/8 and 1-1/2" Threadless, Campy style upper with 1-1/2" lower, cartridge bearings
STEM
Raceface Turbine, 70mm
HANDLEBARS
Raceface Atlas ½” Riser, Stealth Black, 785mm width
GRIPS
Specialized SIP XL Locking Grips
FRONT BRAKE
Avid Elixir 9, 203mm Rotor
REAR BRAKE
Avid Elixir 9, 180mm Rotor
FRONT DERAILLEUR
SRAM X7, 10-speed, S3 direct mount for DMD, bottom-pull
REAR DERAILLEUR
SRAM X0, 10-speed, mid cage
SHIFTERS
SRAM X9, 10-speed, trigger
CASSETTE
Shimano SLX HG81 11-36T 10spd
CHAIN
Shimano SLX HG75 10spd
CRANKSET
Custom SRAM carbon S-2200, 10-speed XC Trail double, PF30 spindle, removable spider, 175mm
CHAINRINGS
Sram 33-24 with Gamut Bash Ring
CHAINGUIDE
Specialized Dangler
BOTTOM BRACKET
FSA PF30, OS press-in bearing, sealed cartridge
RIMS
Roval Traverse 29, alloy disc, 28mm, 32h
FRONT HUB
Roval Traverse 29, 15mm thru-axle caps, 32h
REAR HUB
Roval Traverse 29 142+, 12mm thru-axle, 32h, 36t Star Ratchet UPGRADE
SPOKES
DT Swiss Super Comp, 2.0/1.65/1.8 stainless
FRONT TIRE
Specialized Butcher, Control Casing, 2Bliss ready 29x2.3"
REAR TIRE
Specialized Ground Control, Control Casing, 2Bliss ready, 29x2.3"
SADDLE
Specialized Henge Expert, Titanium rails, 143mm width
SEATPOST
Specialized Command Post BlackLite, 3 position, adjustable height w/air spring, remote operated, single bolt head 30.9mm, 125mm
SEAT BINDER
Specialized Command Post Bolt-on Seat Collar, 34.9Photo
3/17/2014 8:07 PM
Still for sale?
