Boise, ID
8/17/2014 2:58am
i always feel guilty about the lack of bike maintenance i perform on my bike. thankfully i'm not riding in harsh elements very often, so keeping the drivetrain lubed, checking bolts and keeping pressures dialed is what i do on a regular basis.
i'm curious to see what kind of maintenance routines some of you have. do you have any tricks or tips to keep things more efficient when working on your bike?
Lube the chain and check bolts around twice a week.
Do a complete bikecheck once a monthe or before every race. A complete teardown twice or three times a year including suspension service and branke bleeding
After washing regimen:
Right now I'm doing a full clean and lube of the drivetrain (includes pulling off the jockey gears), clean and lube stanchions, relube pedal pivots.
Between washing:
Clean and lube drivetrain.
About every 6 months I do a full teardown.
shock/fork psi monthly
clean/lube chain when it needs it - usually every 3rd-4th ride
bolt check monthly unless i hear a noise i shouldn't
suspension oil and seals every 6 months
pivot bearings checked yearly and replaced/repacked as needed
living in the desert i rarely actually wash my bikes. just hit them with the air compressor when the dust and dirt buildup gets heavy.
Every Monday I check air pressure in the fork and shock, wipe and lube the chain, check steering hardware and check torque on all rear suspension hardware-had an issue with stuff being loose back there (insert that's what she said joke)
After any wicked muddy ride, I hose and let it air dry and redo pretty much everything
Full winter rebuild
Post a reply to: What's your bike maintenance schedule like?
