Switching bmx to mtb (street & dj), and single speed conversion help?
Edited Date/Time:
2. the cranks would fit if you got a euro bb that matches the cranks spindle
3. pedals work with almost any crank arms
heres some links for ur single speed stuff
get some thing like this as a chain Tensioner cuz you have vertical dropouts
http://www.jensonusa.com/store/product/RD707Y01-Surly+Singleator.aspx
http://www.jensonusa.com/store/sub/1874-Single+Speed+Components.aspx
1. take the front wheel off
2. find a torx head to fit the bolts on the disk
3. take the caliper off the fork with the 2 5mm bolts that bolt it on
4. take the left grip off
5. loosen the bolt that hold the lever on
6. ohhh ya while your there loosen the bolt that hold the shifter on
7. there should be a bolt holding the front derailer on take that off
8. there are two ways to get the derailer off the chain you can cut a slot in front derailer or use a chain breaker to break the chain
9. take the cranks off and take the first chain ring off put your cranks back on and tighten your bolts
10. put the single speed pack on and shorten the chain to the rite tension
There you go you have a single speed bike!!
Edited Date/Time:
http://www.pinkbike.com/video/35368 or
http://www.youtube.com/watch?v=KOOxSaDDV5I
Hardtails can do everything duals can. Well... almost.
thanks alot it does not sound that hardjusta10custom wrote: its not that hard sorry couldnt find a vid
thanks, ya im stocked on going to ride with it when i get the job donefoxrider18 wrote: Congrats on switching to the 26'' world for street!
I am currently building the same thing, but different parts etc. I got a tension system known as the "no deraileur" that connects to the same chrome hanger as your rear deraileur and its made by Axiom. I also bought a single speed kit that came with spacers to take the space of all your cogs, and a 16tooth cog/rear sprocket. I also suggest using the gear ratio of having your front chain ring exactly twice as many teeth as your cog, like I am using a 32tooth for my 16tooth. You could convert it to a dialed dj bike for under $100. Feel free to check out my photo album to see the build so far and get an idea. Any more questions during your build, send me a message because the process is fresh in my head! Theses link may help.
Edited Date/Time:
Edited Date/Time:
yupC-burn wrote: does your shred still have a dual chain ring up front
Edited Date/Time:
yupC-burn wrote: Are you planning on switching it out?
well i am making it single speed so i am switching it out. I think i know how to loljusta10custom wrote: do you know how get it off
