Steertubes
Billy3197
Vital MTB member Billy3197
11757 Billy3197 /images/default/avatar/c50.png http://www.vitalmtb.com/community/Billy3197,11757/all 11/20/11 1 6 4 21 15 1
2/28/2012 4:44 PM
Is it possible to change a fork with a tapered steer tube to straight? as in- buy a tapered fork and put a different steer tube on it.
Vital MTB member bturman
109 bturman http://p.vitalmtb.com/photos/users/109/avatar/c50_BT_20150715_untitled_shoot_016_6_2_1478284381.jpg?1478283449 http://www.vitalmtb.com/community/bturman,109/all 08/01/09 1150 94 6120 1028 http://www.vitalmtb.com/community/bturman,109/setup 274 1211 2178 136 41
Administrator
2/28/2012 10:20 PM
*Moved to the mechanics forum.
NoahColorado
Vital MTB member NoahColorado
128 NoahColorado http://p.vitalmtb.com/photos/users/128/avatar/c50_88160290_1258334763.jpg?1290150194 http://www.vitalmtb.com/community/NoahColorado,128/all 08/01/09 1 3 364 29 http://www.vitalmtb.com/community/NoahColorado,128/setup 4 96 404 6
2/28/2012 10:34 PM
Edited Date/Time: 2/28/2012 10:35 PM
In short: no.
You'd also need a new crown and most manufacturers aren't keen on reusing your stanchions either. So you'd really need what's called a "CSU" - which is a fresh crown, steerer, and stanchions (uppers). That'll cost you at least $300 at retail - a costly endeavor.
However, it is possible on some frames to fit a tapered steerer in a head-tube originally designed for a straight steerer. If you're frame uses an 1-1/8" zero stack lower headset, there are conversion headsets now available from Cane Creek and others to externalize your headset and fit a tapered steerer. This only works on Zero Stack headsets with pressed-in cups, not the IS style where the bearing sits directly in the frame.
Vital MTB member Big Bird
6576 Big Bird http://p.vitalmtb.com/photos/users/6576/avatar/c50_SmileySmall.jpg?1320728633 http://www.vitalmtb.com/community/Big-Bird,6576/all 02/01/11 9 49 1122 2785 13
Moderator
3/3/2012 9:54 AM
Edited Date/Time: 3/3/2012 9:55 AM
It will void your warranty and possibly your life, but I have replaced two steertubes in forks. I used 7000 series aluminum and a healthy amount of press fit. One was on a Manitou Super Nova single crown. The other was a bit safer as it was on a Dorado triple clamp. Neither one has given me any problems. I don't recommend it, but it can be done.
