Scott Spark Fork Debacle
SVEGE
Vital MTB member SVEGE
29615 SVEGE /images/default/avatar/c50.png http://www.vitalmtb.com/community/SVEGE,29615/all 02/08/14 1 2 1
2/8/2014 2:32 PM
I just bought a Scott Spark and the front fork is a bit too soft for me. How much bigger can I go on the front end of this thing without compromising anything? is 120 the max i can throw on there? or should i throw a 26" front wheel on it and go 170mm and make it look like one of the bmx bikes from gummo.
Vital MTB member bturman
109 bturman http://p.vitalmtb.com/photos/users/109/avatar/c50_profile_1487817150.jpg?1487816891 http://www.vitalmtb.com/community/bturman,109/all 08/01/09 1118 96 6155 952 http://www.vitalmtb.com/community/bturman,109/setup 276 1271 2318 170 41
Administrator
2/10/2014 7:43 AM
If it's too soft (by which I assume you mean you're using the travel too quickly/easily), try pumping the fork up if it's air sprung or getting a firmer spring if it's coil sprung.
SVEGE
2/10/2014 11:00 AM
Is it possible to run a 120 air on the spark?
Administrator
2/10/2014 11:06 AM
You're on the 29er model, yeah? Swapping the stock 100mm travel fork for a 120mm will slacken the head angle slightly (a good thing imo) and raise the bottom bracket height a tad. The Spark's bottom bracket is quite low to begin with, so that should be fine.
SVEGE
2/10/2014 11:12 AM
Yeah. 29er. Thanks for the answer. Appreciate it.
