close
Participating Members
WOOD LIPS
1/16/2011 1:50 PM
I now have a nice step-up mulch landing in my yard, and I need to build a decent wood lip to go with it... Does anyone have plans or just basic numbers for good wood lips, like the kind at AT showdown? ..maybe not quite that large, but any plans will scale... things like take off angle and curve radius are things I'm curious about.
BMA Film Festival coordinator
1/16/2011 5:42 PM
AT texted the dimensions of the jumps in his contest, so it should be a good starting point for ya.
- big ramps - 8ft tall with 14ft radius
- smaller ramp (last jump) - 6ft tall with 10ft radius
1/28/2011 6:34 PM
depends if you want height or distance.. i usually cut all mine at around 12" 6inch radius @ 6ft .. my gap is usually around 12ft lip to landing..
a 10ft Radius is going to pop you nice.. however.. you won't be able to do quite as much at higher speeds...i guess it depends on your riding style and what you're doing.
1/28/2011 8:35 PM
Im a big fan of the Wood Kicker, is this what you had in mind?
1/29/2011 5:31 PM
Edited Date/Time: 1/29/2011 5:36 PM
Thanks for the numbers and pictures, super helpful... I ended up going with a 10' radius and kept it small, around 4'6" tall. The landing is mulch, piled up behind a rock wall (don't come up short!!!). It's also a little bit of a step-up so the landing is very forgiving. This thing is perfect for me for now, I see larger ones in the future....
1/29/2011 5:35 PM
3/20/2011 7:41 PM
cool as you should upload some pictures of it in use
DJALLDAY
5/25/2011 3:39 PM
sspomer wrote: AT texted the dimensions of the jumps in his contest, so it should be a good starting point for ya.
Good to know.
We will be replacing a couple dirt jumps with larger wood kickers this summer.
Anyone have the numbers of the Post Canyon Booters?
11/7/2011 10:18 AM
Tarka, what did the radius of the jump you built end up as? I like the framing design.
FMX left side jumps in PC have a 10-14 foot radius, I believe.
11/7/2011 10:51 AM
14' seems like a good test case. We will be constructing soon, dirt is almost soft enough to manage again.
The take-off in my avatar is going to be the first one replaced with a larger wood version. Thanks for the info everyone.
2/18/2012 8:07 PM
How did you guys make the jumps so smooth? could somebody post a pic of the support system mabe
Post a Reply to: WOOD LIPS
