rear derailleur cage width
david.nixon.1965
Vital MTB member david.nixon.1965
22810 david.nixon.1965 http://p.vitalmtb.com/photos/users/22810/avatar/c50_fb_picture_1088388878.jpg?1363498620 http://www.vitalmtb.com/community/david-nixon-1965,22810/all 03/16/13 1 2 1
3/16/2013 11:04 PM
Edited Date/Time: 3/16/2013 11:05 PM
Have cage widths decreased along with chain widths over time? I really want to get the Shimano Zee which is meant for 10 speed chains. That could be upto a difference of 1.6 mm between a 10 speed chain and an 8 speed chain. Will the 8 spd chain fit thru this cage?
Sorry for the silly question but I have gone back to an 8 speed setup and I would love to be able to use this short cage clutch system. At 9 speed, I started breaking chains too often (shimano and sram) and that didn't happen in my 8 spd days.
talking spoon
Vital MTB member talking spoon
22413 talking spoon http://p.vitalmtb.com/photos/users/22413/avatar/c50_IMAG0637.jpg?1362057928 http://www.vitalmtb.com/community/talking-spoon,22413/all 02/28/13 http://www.vitalmtb.com/community/talking-spoon,22413/setup 7
3/17/2013 6:59 PM
it wont work because the new 10spd derailleurs have different pull ratios then the 9 and 8 spd stuff
david.nixon.1965
3/18/2013 6:30 AM
I thought all derailleurs are moved based on what the shifter is doing. I used an 8 speed (1994) der for years with a 9 speed shifter. That's why I thought this would work except for possibly issues with the width of the chain and the width of the cage it's traveling thru.
Vital MTB member Big Bird
6576 Big Bird http://p.vitalmtb.com/photos/users/6576/avatar/c50_SmileySmall.jpg?1320728633 http://www.vitalmtb.com/community/Big-Bird,6576/all 02/01/11 9 49 1122 2785 13
Moderator
3/18/2013 6:58 AM
For years, all derailleurs had the same leverage ratio and you could mix and match. But then Sram came up with their 1:1 ratio and you couldn't mix parts from Sram and Shimano. Now, with ten and eleven speed systems, ratios are changing again.
david.nixon.1965
3/19/2013 12:07 PM
I see, thanks for the info. In the meantime, I found a 9 spd xtr short cage that should work for me.
