please help!!!!!!!
Tman
Vital MTB member Tman
6539 Tman /images/default/avatar/c50.png http://www.vitalmtb.com/community/Tman,6539/all 01/30/11 2 3 1
5/28/2011 5:47 PM
i have just bought a pair of new pedals to replace my old ones. this morning i thought i would put the new ones on. i got the left one off no trouble but no matter how hard i try i cant get the right one off .... ive tried everything but it still wont come off ...
any ideas would be a HUGE HELP!!!!
Vital MTB member bturman
109 bturman http://p.vitalmtb.com/photos/users/109/avatar/c50_profile_1487817150.jpg?1487816891 http://www.vitalmtb.com/community/bturman,109/all 08/01/09 1137 96 6156 1023 http://www.vitalmtb.com/community/bturman,109/setup 275 1223 2224 148 41
Administrator
5/28/2011 5:51 PM
This might be obvious, but are you turning it the correct direction? Left and right pedals are threaded differently, and they loosen towards the back of the bike.
kidwoo
Vital MTB member kidwoo
316 kidwoo http://p.vitalmtb.com/photos/users/316/avatar/c50_fastesttoilet_1403751711.jpg?1403751102 http://www.vitalmtb.com/community/kidwoo,316/all 08/03/09 5 36 8 3 185 634 2 2
5/28/2011 6:01 PM
Put your right crank at 3 o'clock (as in level if you ride right foot forward). Get your pedal wrench as parallel as possible with the handle pointing towards the rear of the bike. Grab your rear brake. Knock the shit out of the handle with a hammer.
Should probably put the bike on the ground.
If that doesn't work, drink a few beers and try the same procedure again.
If that doesn't work, do a fat line of coke and try the same procedure again.
canadmos
Vital MTB member canadmos
7170 canadmos /images/default/avatar/c50.png http://www.vitalmtb.com/community/canadmos,7170/all 03/11/11 http://www.vitalmtb.com/community/canadmos,7170/setup 39 327 1
5/28/2011 6:16 PM
And when you put your new pedals back on, be sure to grease the threads and don't do them up too tight! Do that and you'll have no problems getting them off in the future.
Tman
5/28/2011 6:26 PM
im defiantly turning the right direction but thanks any way
Tman
5/28/2011 6:30 PM
a pedal wrench?? that might be my problem. ive worn the nut down so much now that my spanner just slips...not good.
Vital MTB member Big Bird
6576 Big Bird http://p.vitalmtb.com/photos/users/6576/avatar/c50_SmileySmall.jpg?1320728633 http://www.vitalmtb.com/community/Big-Bird,6576/all 02/01/11 9 49 1127 2800 13
Moderator
5/28/2011 7:15 PM
If ALL else fails, sometimes a dose of that good cleansing fire will do the trick. Break out the blow torch and heat the area. Aluminum expands more/faster than steel, so the threads should loosen a bit. Turn it while it's hot, turn it while it's hot. Sorry, couldn't resist. Also, the heat can burn away some of the rust and grease, making the process easier as well.
Administrator
5/28/2011 7:49 PM
If the wrench flats are stripped, you may have an alley key insert on the back side of the pedal.
Tman
5/28/2011 10:01 PM
nope
flozza
Vital MTB member flozza
7067 flozza /images/default/avatar/c50.png http://www.vitalmtb.com/community/flozza,7067/all 03/06/11 http://www.vitalmtb.com/community/flozza,7067/setup 1 17
5/29/2011 3:41 AM
vice grips+ a long lever attached works well
moto_geek
Vital MTB member moto_geek
8188 moto_geek http://p.vitalmtb.com/photos/users/8188/avatar/c50_seaotter_1.jpg?1305733441 http://www.vitalmtb.com/community/moto-geek,8188/all 05/18/11 3 3 2
6/8/2011 11:06 AM
Edited Date/Time: 6/8/2011 11:07 AM
TMan, check the back side of the pedal, some pedals have an allen key as well. If you don't have a allen key on the back side of the pedal, I would recommend taking to your local shop before you make the nut part worst. A pedal wrench goes a long ways. I found out the hard way as well. The heating is a good tip, just be careful not to melt the inner bearing seal next to the crank.
Give us an update when you have a chance.
Team AdverNETS Rider - Rob "Big Hurt"
AdverNETS Internet Solutions http://www.advernets.com
