Sun Ringle Demon Hub - Removing drive side sealed bearing
lonelyplanetrider
Vital MTB member lonelyplanetrider
14782 lonelyplanetrider http://p.vitalmtb.com/photos/users/14782/avatar/c50_th_80by80.jpg?1353253560 http://www.vitalmtb.com/community/lonelyplanetrider,14782/all 04/11/12 1 2 3 13
5/15/2013 1:06 AM
Hi all. Need a little help getting out the drive side bearing from my Sun Ringle hub without damaging the ratchet teeth for the freehub. Can't tap out the bearing without it hitting the teeth. The bearing is a 6002-2RS with significant play that it really needs to come out.
Any suggestions anyone?
The hub has sentimental value, so I'd rather just replace the bearing rather than get a new rear hub.
Zoro
Vital MTB member Zoro
1926 Zoro http://p.vitalmtb.com/photos/users/1926/avatar/c50_IMG_2339_flat_tire.jpg?1350230883 http://www.vitalmtb.com/community/Zoro,1926/all 02/10/10 20 64 1
5/15/2013 10:16 AM
Tap it with a punch from the non-drive side?? That's how do it most of the time
lonelyplanetrider
5/15/2013 12:56 PM
Already tried that step, and the bearing gets stuck on the ratchet teeth somehow. Friend of mine suggested a bearing puller. Hopefully I can find one.
haos3
Vital MTB member haos3
27001 haos3 /images/default/avatar/c50.png http://www.vitalmtb.com/community/haos3,27001/all 08/22/13 1
8/22/2013 9:47 AM
Hi, first you must remove ratchet ring to do it you need BSHUBTOOL2 (only if you have 30 teeth).
