Replacing regular forks with suspension forks?
RobxC
Vital MTB member RobxC
8274 RobxC /images/default/avatar/c50.png http://www.vitalmtb.com/community/RobxC,8274/all 05/24/11 1 1
5/24/2011 9:28 AM
Edited Date/Time: 5/24/2011 10:09 AM
I've got the scott yz 0.2 (2011) And Im looking to replace the forks with rock shox dart one suspension forks, How would I do this? and would I need different bearings or stem?
Vital MTB member bturman
109 bturman http://p.vitalmtb.com/photos/users/109/avatar/c50_profile_1487817150.jpg?1487816891 http://www.vitalmtb.com/community/bturman,109/all 08/01/09 1137 96 6156 1023 http://www.vitalmtb.com/community/bturman,109/setup 275 1223 2223 147 41
Administrator
5/24/2011 12:56 PM
The only thing you'll need (besides the new fork), it a star-nut. It's a funky little nut that gets jammed inside of the steerer tube and holds your stem tight. Your stem and headset/bearings will work just fine with the new fork.
If it's your first time changing out forks, I'd suggest taking it to a shop and watching them do it so you can learn the process.
RobxC
5/26/2011 10:00 AM
Ive replaced bmx forks before and that worked fine, thanks for the advice bro
MXRACER
Vital MTB member MXRACER
11808 MXRACER /images/default/avatar/c50.png http://www.vitalmtb.com/community/MXRACER,11808/all 11/23/11 1
11/23/2011 5:26 AM
What about if my Star nut doesn't seem to get tight ? is there a torque spec on this nut ? I am having problem keeping my headset bearings tight.
Vital MTB member Big Bird
6576 Big Bird http://p.vitalmtb.com/photos/users/6576/avatar/c50_SmileySmall.jpg?1320728633 http://www.vitalmtb.com/community/Big-Bird,6576/all 02/01/11 9 49 1127 2800 13
Moderator
11/23/2011 10:56 AM
Generally, the star nut is always over sized and is press fit into the steertube. In the course of my wrenching career, I've only seen a couple of star nuts that slipped in the fork. If that's the case, smack it out the bottom and try a new one. Otherwise, you may not be tightening your (Side) stem bolts enough so that when you beat on it, the steer tube can flex a bit and pull the star nut up the tube. Check that.
Administrator
11/23/2011 12:05 PM
Edited Date/Time: 11/23/2011 12:05 PM
Are you loosening your stem bolts before tightening your star nut bolt, and then retightening the stem bolts? The order is important. Your stem has to be loose in order for the headset to get tightened.
