I wanted to build a bike that wasn't super blingy and touchy, just solid and something I could travel with. I have no idea on weight but my finely calibrated hand puts it at about 36-37 lbs, perfectly reasonable for my usage: primarily freeride, few races, and traveling this summer.
Few notes about the bike:
-Wet Screams - The northeast is a mess right now after a wet winter, scoping some fresh lines right now and these are necessary, they will be replaced with minions when it dries out
-e.13 Cranks - 170mm is about right for me with lo pro pedals, these things are brilliant, giant bearings and easy installation/removal I really can't see a bad side
-Size - The bike is a medium, I am 5'10 and typically ride smalls because i like smaller bikes...this frame is dialed for my height just right
-Rear Dropout - Read some concerns about rear wheel changing and the chip flying out...Once you get the cables mounted the rear wheel removal and installation is a breeze but the 3mm lock screw is a bit odd, we need at least a 4mm
-Shock installation - I had to unbolt the linkage to get the fox in there, maybe im an moron, maybe not, but the rebound is a bit tough to adjust
-Build Quality - It is above almost everything transition has done in the past and I am a vet owner, an already great company stepped it up
All around beauty - When you see one of these in person you will get it, it's the perfect park/short travel race bike
With my blue baby
xc mode
Spec
Frame: Transition TR250 Flat Black Medium
Shock: Fox Coil DHX 4
Bars: Gravity Light
Stem: Thompson
Headset: E.13 cup low stack
Grips: Ruffian
Fork: Rock Shox Totem Air
Rotors: 203/185mm Saint
Brake Lever: Saint
Brake Caliper: Saint
Shifter: X.O
Derailure: X.9
Cassette: Shimano Road
Crank: e.13 w/ BB
Ring: E.13 36t Black
Guide: E.13 LG1+ Black
Chain: SRAM PC 99
Seatpost: Thompson
Seat Clamp: Transition
Seat: WTB Silverado
Pedals: Canfield Brothers Crampon
Hubs: Hope Pro II Black & Chub (f)
Rims: Transition Silver
Spokes: Black Straight Guage
Nipples: Silver
Tires: Wet Screams
