close
RSS feed hosed
11/23/2010 8:25 AM
The RSS feed is linking to 404'd pages.
11/23/2010 4:04 PM
jasonvelocity wrote: The RSS feed is linking to 404'd pages.
Yeah, whoops! We were testing out some new settings but have it all back in order now. Sorry for the hiccup.
11/29/2010 8:14 AM
More RSS issues:
"500 Internal Server Error
If you are the administrator of this website, then please read this web application's log file to find out what went wrong."
Here is the URL in my RSS feed: http://www.vitalmtb.com/news/news/Tweets-of-the-Week-November-21-28-2010,211?utm_source=feedburner&utm_medium=feed&utm_campaign=Feed%3A+VitalMtbSpotlights+%28Vital+MTB+Spotlights%29&utm_content=Google+Reader
11/29/2010 9:07 AM
And now a different error:
http://feeds.vitalmtb.com/www.vitalmtb.com/forums/Springs-N-Things,4/New-Shock,5244
There has been an error of some kind. Ack!
FeedBurner could not deliver this feed to you because of the specific problem listed below:
Feed Address: http://feeds.vitalmtb.com/www.vitalmtb.com/forums/Springs-N-Things,4/New-Shock,5244
HTTP Error (Code) and Message: (404) Feed not found error: FeedBurner cannot locate this feed URI.
What can I do about this?
If you are a potential or current subscriber, contact the publisher to notify them that their feed content is not available. This may be temporary problem that requires their intervention to resolve, or the publisher may have permanently removed the feed from FeedBurner.
If you are the publisher of this feed, sign into FeedBurner and visit your feed's “Troubleshootize” tab to view FeedMedic, our automated diagnostic report for your feed. A cause for the problem, and tips for troubleshooting it, may be found there.
11/29/2010 9:13 AM
Thanks for the heads up. We've recently recoded the entire site (look around, you'll see some changes) which has caused a few bad links to get pushed. Our RSS feed should be back up to speed shortly.
11/29/2010 10:09 AM
Hey jasonvelocity,
As Brandon mentioned, we've recently completely changed back end of the site. Couple errors may have creeped in during transition but everything should work fine from now on. If you see any more issues, you can post here or email me directly at afarennikov@vitalmedianet.com.
11/30/2010 6:18 AM
12/1/2010 8:51 AM
12/8/2010 11:10 AM
...and today:
http://www.vitalmtb.com/news/press-release/Royal-Racing-to-Sponsor-Trek-World-Racing,222?utm_source=feedburner&utm_medium=feed&utm_campaign=Feed%3A+VitalMtbSpotlights+%28Vital+MTB+Spotlights%29&utm_content=Google+Reader
Ruby on Rails application could not be started
These are the possible causes:
There may be a syntax error in the application's code. Please check for such errors and fix them.
A required library may not installed. Please install all libraries that this application requires.
The application may not be properly configured. Please check whether all configuration files are written correctly, fix any incorrect configurations, and restart this application.
A service that the application relies on (such as the database server or the Ferret search engine server) may not have been started. Please start that service.
Further information about the error may have been written to the application's log file. Please check it in order to analyse the problem.
Error message:
uninitialized constant HoptoadNotifier
Exception class:
NameError
Application root:
/opt/nginx/html/sites/recode
Backtrace:
# File Line Location
0 /usr/local/lib/ruby/gems/1.8/gems/activesupport-2.3.8/lib/active_support/dependencies.rb 443 in `load_missing_constant'
1 /usr/local/lib/ruby/gems/1.8/gems/activesupport-2.3.8/lib/active_support/dependencies.rb 80 in `const_missing_not_from_s3_library'
2 /usr/local/lib/ruby/gems/1.8/gems/aws-s3-0.6.2/lib/aws/s3/extensions.rb 206 in `const_missing'
3 /usr/local/lib/ruby/gems/1.8/gems/activesupport-2.3.8/lib/active_support/dependencies.rb 92 in `const_missing'
4 /opt/nginx/html/sites/recode/config/initializers/hoptoad.rb 1
5 /usr/local/lib/ruby/gems/1.8/gems/activesupport-2.3.8/lib/active_support/dependencies.rb 147 in `load_without_new_constant_marking'
6 /usr/local/lib/ruby/gems/1.8/gems/activesupport-2.3.8/lib/active_support/dependencies.rb 147 in `load'
7 /usr/local/lib/ruby/gems/1.8/gems/rails-2.3.8/lib/initializer.rb 622 in `load_application_initializers'
8 /usr/local/lib/ruby/gems/1.8/gems/rails-2.3.8/lib/initializer.rb 621 in `each'
9 /usr/local/lib/ruby/gems/1.8/gems/rails-2.3.8/lib/initializer.rb 621 in `load_application_initializers'
10 /usr/local/lib/ruby/gems/1.8/gems/rails-2.3.8/lib/initializer.rb 176 in `process'
11 /usr/local/lib/ruby/gems/1.8/gems/rails-2.3.8/lib/initializer.rb 113 in `send'
12 /usr/local/lib/ruby/gems/1.8/gems/rails-2.3.8/lib/initializer.rb 113 in `run'
13 /opt/nginx/html/sites/recode/config/environment.rb 9
14 /usr/local/lib/ruby/site_ruby/1.8/rubygems/custom_require.rb 31 in `gem_original_require'
15 /usr/local/lib/ruby/site_ruby/1.8/rubygems/custom_require.rb 31 in `require'
16 /root/src/passenger-2.2.15/lib/phusion_passenger/railz/application_spawner.rb 318 in `preload_application'
17 /root/src/passenger-2.2.15/lib/phusion_passenger/railz/application_spawner.rb 267 in `initialize_server'
18 /root/src/passenger-2.2.15/lib/phusion_passenger/utils.rb 323 in `report_app_init_status'
19 /root/src/passenger-2.2.15/lib/phusion_passenger/railz/application_spawner.rb 246 in `initialize_server'
20 /root/src/passenger-2.2.15/lib/phusion_passenger/abstract_server.rb 194 in `start_synchronously'
21 /root/src/passenger-2.2.15/lib/phusion_passenger/abstract_server.rb 163 in `start'
22 /root/src/passenger-2.2.15/lib/phusion_passenger/railz/application_spawner.rb 222 in `start'
23 /root/src/passenger-2.2.15/lib/phusion_passenger/spawn_manager.rb 253 in `spawn_rails_application'
24 /root/src/passenger-2.2.15/lib/phusion_passenger/abstract_server_collection.rb 126 in `lookup_or_add'
25 /root/src/passenger-2.2.15/lib/phusion_passenger/spawn_manager.rb 247 in `spawn_rails_application'
26 /root/src/passenger-2.2.15/lib/phusion_passenger/abstract_server_collection.rb 80 in `synchronize'
27 /root/src/passenger-2.2.15/lib/phusion_passenger/abstract_server_collection.rb 79 in `synchronize'
28 /root/src/passenger-2.2.15/lib/phusion_passenger/spawn_manager.rb 246 in `spawn_rails_application'
29 /root/src/passenger-2.2.15/lib/phusion_passenger/spawn_manager.rb 145 in `spawn_application'
30 /root/src/passenger-2.2.15/lib/phusion_passenger/spawn_manager.rb 278 in `handle_spawn_application'
31 /root/src/passenger-2.2.15/lib/phusion_passenger/abstract_server.rb 352 in `__send__'
32 /root/src/passenger-2.2.15/lib/phusion_passenger/abstract_server.rb 352 in `main_loop'
33 /root/src/passenger-2.2.15/lib/phusion_passenger/abstract_server.rb 196 in `start_synchronously'
34 /root/src/passenger-2.2.15/bin/passenger-spawn-server 61
Powered by Phusion Passenger, mod_rails / mod_rack for Apache.
Post a Reply to: RSS feed hosed
